Ranking de donantes
High quality XTAR IMR 18650 3.6V 2900mAh Li-ion battery
27 Mar 2015 11:48 #1
Lightmalls
Profesional
Desconectado
Dear friend.
NEW High Quality 18650 Battery for your reference. Pls check here:
XTAR IMR18650 3.6V 2900mAh 10Amp High Drain Li-ion Rechargeable Battery Without PCB For Fashlights and Electronic Cigarette
Features:
* 2900mAh high capacity
* Specially designed for high-performance flashlights and electronic cigarette
* Improved voltage stability due to low internal resistance
* Innovative structure design, ensures impact-resistant, effectively protects the battery
* economical and eco-friendly
10Amp High Drain battery
Voltage: 3.6V
Battery Capacity: 2900mAh Protection: Non
Size(mm): φ18.4±0.2mm(body diameter)x 66.5±0.5mm (length)
Rechargeable
Notice: The above-mentioned parameters tested in Lab are approximate and may vary between flashlight/charger, batteries.
Volver a Lightmalls
¿Quién está conectado?
ForoLinternas ©
