Ranking de donantes
Professional XTAR D06 Diving CREE XM-L U2 LED Flashlight
07 Abr 2015 10:39 #1
Lightmalls
Profesional
Desconectado
Dear friend.
How was your weekend?
Do you like Diving?If yes , this diving flashlight may meet your need . check here:
XTAR D06 100m Diving CREE XM-L U2 LED Flashlight Max 820 Lumen LED Diving Flashlight (1*18650)
50,000 hours lifespan CREE XM-L U2 LED
Max output 820 lumens;
Max Duration: 3Lm/325 hours
SMO reflector, throws beam over 270 meters
Electrodeless magnetic control switch
Constant circuit constant brightness
Power by 1*18650/18700(3.7V) Li-ion battery(Not inlcude)
Made of anodized aircraft 6061 aluminum
Amphibious 100m deep diving sealed compression resisted design
Safety switch design
2.75~4.2V voltage range
Size: 45.0mm(head dia) * 30.0mm(body dia) * 148.5mm(length)
Net Weight: 210g
Notice: The above-mentioned parameters tested in Lab are approximate and may vary between flashlight/charger, batteries and environments.
07 Abr 2015 17:41 #2
pepitogrito
Desconectado
Re: Professional XTAR D06 Diving CREE XM-L U2 LED Flashlight
Ese tipo de Power, es el que yo siempre tuve en mente. Aunque, en mi caso, no sobresalía tanto... :silbando: Pero el "conceto" es ese, ni más ni menos. Y, a falta de probarlo, (hay videos y parece funcionar de maravilla), me parece de lo más práctico en una linterna... :sisi3:
Última edición por pepitogrito el 09 Abr 2015 15:53, editado 1 vez en total
09 Abr 2015 11:34 #3
Lightmalls
Profesional
Desconectado
Hello,friend.
So you are interested in this diving flashlight?
Yes, this is a quite practical flashlight, we also know that if have the video will be better, but now this flashlight not in our office, so can not take a video .
But this flashlight is brand name flashlight, in high quality .
02 Jul 2015 18:38 #4
Carmi
Desconectado
Usuario baneado
Professional XTAR D06 Diving CREE XM L U2 LED Flashlight
I got a cree 6000 lumen head light that I can run my boat in the dark with.
Volver a Lightmalls
¿Quién está conectado?
ForoLinternas ©
