Ranking de donantes
Imalent DN35---a powerful led flashlight up to 2200 lumrns
04 Ene 2017 10:05 #1
Imalent
Profesional
Desconectado
Product Details
The IMALENT DN35 is a versatile USB rechargeable LED tactical flashlight with multi-level outputs and an OLED display. The OLED display shows the battery voltage, output, charging status, and has a flashing overheat warning, which makes it easier to know the status of the flashlight. Utilizing the latest four-level output CREE XHP35 HI LED, the tactical-switch button makes it easy to operate. With a maximum output of up to 2200 lumens, the IMALENT DN35 can produce a strong beam of light up to 596meters away. Supported by a single cell of IMALENT 26650 4500mAh Li-ion rechargeable battery, its advanced temperature control module, low-voltage warning, and low-power protection make for a satisfying experience no matter the occasion.
Product Features
·Utilizes the latest CREE XHP35 HI LED. The lifespan up to 50000 hours with ·maximum output of 2200 lumens. Includes a built-in USB charging interface
·The OLED display can show various parameters.With high drain 4500mAh 26650 Li-
·ion rechargeable battery
·Product size: 113(length)*38 (head diameter) *32 (diameter) mm
·Net weight:115g
·High efficiency constant power circuit will maintain constant brightness
·Anti-reverse battery protection
·Built-in thermal control module will automatically adjust the brightness output
·according to the working state and outer temperature
·Combination of toughened ultra-clear mineral and anti-reflective coating glass
·Optimized deep metal reflector maintains great throw distance and spread with an ·ideal beam pattern
·Aerospace-grade aluminum alloy body, wear-resistant Type III hard-anodized surface
·treatment
·IPX-8 standard waterproof (2 meters submersible)
·1.5m impact resistant
·Tail stand function
We are looking for dealers and distributors worldwide. Please send us email at sales@imalent.com if any interest.
Best regards,
Shellen
IMALENT marketing team
Skype: imalent_shellen
20 Abr 2017 22:20 #2
joseabul
Desconectado
Re: Imalent DN35---a powerful led flashlight up to 2200 lumr
Tendrán que revisar las specs que dan de esta linterna porque de 88900cd ni en sus mejores sueños.
Utilizando el mismo luxómetro que he utilizado con otras primeras marcas y cuyas lecturas sí se ajustan a los datos dados por la mayoría de los fabricantes, he medido lecturas en la DN35 en el modo turbo y no llega ni a los 50000 cds. Es mucha diferencia.....
Con respecto a los lúmenes no puedo dar datos, pero el salto de 1500 a 2200, apenas se aprecia visualmente..... Decepcionado por no decir otra palabra que empieza por E. :nono:
Espero que con los demás modelos no sigan los mismos criterios, por el bien de futuribles pollos.
01 May 2017 13:35 #3
chinokemao2
Desconectado
Usuario baneado
joseabul escribió:Tendrán que revisar las specs que dan de esta linterna porque de 88900cd ni en sus mejores sueños.
no te molestes, estos nunca responden, ni a los correos cuando les dices que no te funciona la linterna
Última edición por chinokemao2 el 01 May 2017 15:03, editado 1 vez en total
01 May 2017 14:53 #4
joseabul
Desconectado
Si, ya leí tu queja y me acordaba de ello cuando hice las mediciones. Pero es que además, parece ser que esta "engañifa" es extensible a otros modelos, porque estuve recopilando información sobre la DT35, y en una review que leí de los 250 klcds y 8000 lúmenes, se quedaban en 150 kcds y 5000 lúmenes. En fin, si siguen con esa "vista comercial" y con esos precios, les auguro un mal porvenir.
01 May 2017 15:06 #5
chinokemao2
Desconectado
Usuario baneado
joseabul escribió:Si, ya leí tu queja y me acordaba de ello cuando hice las mediciones. Pero es que además, parece ser que esta "engañifa" es extensible a otros modelos, porque estuve recopilando información sobre la DT35, y en una review que leí de los 250 klcds y 8000 lúmenes, se quedaban en 150 kcds y 5000 lúmenes. En fin, si siguen con esa "vista comercial" y con esos precios, les auguro un mal porvenir.
Volver a Imalent
¿Quién está conectado?
ForoLinternas ©
