Ranking de donantes
NEW RELEASE!! Imalent SA04 2016 VERSION!
12 Dic 2015 10:39 #1
Imalent
Profesional
Conectado
Imalent S series
New version! Imalent SA04 2016 VERSION
IMALENT SA04 2016, perfect upgrade of SA04:
1. Added camera tripod
2. Button switches have been upgraded to more convenient touch switches on both sides
3. Reflector suspended processed, make it better for throw
4. All contact points of the circuit with gold-plating to prevent oxidation and improve efficiency
5. Better design
6. Can support rechargeable AA battery (many AA size battery flashlight unable to support because rechargeable ones a little bigger)
It is a compact AA powerful flashlight with many useful features, like modern touch switch, variable color temperature, LCD touch screen controlled. The best feature variable color temperature flashlight make it like two flashlights in one, save you one flashlight on money and weight.
20 Ene 2016 16:38 #2
Quemapilas
Desconectado
Re: NEW RELEASE!! Imalent SA04 2016 VERSION!
Interesante, pero no sabemos la potencia de los RGB.
Tampoco entiendo porque dos diodos y uno es versión L y el otro L2.
Del resto mola mucho y para fotógrafos puede estar muy bien.
La oscuridad es barata.
21 Ene 2016 06:15 #3
Imalent
Profesional
Conectado
Quemapilas escribió:Interesante, pero no sabemos la potencia de los RGB.
Hi,
Thank you for follow up.
David
Volver a Imalent
¿Quién está conectado?
Usuarios navegando por este Foro: Imalent y 1 invitado
ForoLinternas ©
