Ranking de donantes
Imalent DT70---a powerful flashlight up to 16000 lumens
31 Dic 2016 11:38 #1
Imalent
Profesional
Desconectado
Hi, Everyone,
Imalent is going to release our DT70, which is so compact but straggering brightness! -- 16000lumens, powered by 4pcs 18650, with USB charging port!
Here are some small description of its advantages:
1. OLED display
2. Up to 16000lumens, with very wide beam and 700meters distance
3. USB rechargeable
4. Can change 18650 easily, without battery magazine
5. Instant turbo mode, just press the left button can get it
6. Special modes included ( strobe, SOS and beacon)
The IMALENT DT70 is a versatile USB rechargeable LED tactical flashlight with multi-level output and an OLED display. The OLED display shows the battery voltage, output, charging status, and has a flashing overheat warning, which makes it much easier to know the status of the flashlight. Utilizing the latest CREE XHP70 LED, its aluminum OP reflector helps distribute the beam more evenly, and can output up to 16,000 lumens. There are four output levels, with the tactical-switch button making it easy to operate.
Supported by 4pcs IMALENT 18650 Li-ion rechargeable batteries, its advanced temperature control module, low-voltage warning and low-power protection make the DT70 the perfect flashlight for any demanding environment or scenario.
Features
·Utilizes the latest CREE XHP70 LEDs, with a lifespan up to 50000 hours with ·maximum output of 16000 lumens. Includes a built-in USB charging interface
·The OLED display can show various parameters
·Product size: 146(length)*70 (head diameter) *50 (diameter) mm
·Net weight:427g
·High efficiency constant power circuit will maintain constant brightness
·Anti-reverse battery protection
·Built-in thermal control module will automatically adjust the brightness output
·according to the working state and outer temperature
·Combination of toughened ultra-clear mineral and anti-reflective coating glass
·Aluminum OP reflector
·Aerospace-grade aluminum alloy body, wear-resistant Type III hard-anodized surface
·treatment
·IPX-8 standard waterproof (2 meters submersible)
·1.5m impact resistant
·Tail stand function
We are looking for dealers and distributors worldwide. Please send us email at sales@imalent.com if any interest.
Best regards,
Shellen
IMALENT marketing team
Skype: imalent_shellen
Volver a Imalent
¿Quién está conectado?
ForoLinternas ©
