Ranking de donantes
IMALENT FLASHLIGHT TIPS FOR NEW MODELS
05 Abr 2017 07:50 #1
Imalent
Profesional
Desconectado
When you receive your IMALENT new models DT70, DT35, DN35 or DN70, follow the steps if it doesn't turn on:
1. Take out the battery protection pcs
2. Screw it as tightly as he can, as the flashlight need high current, so if not tight enough, it won't be able to pass 15A current.
3. If it still doesn't work, use cloth to clean the contact parts like battery tube and the copper rings inside the flashlight head.
4. When press the right button, make sure it is just click but not hold it as hold it for 1 second will be turn the light off, so the flashlight will not turn on when you hold it.
5. Do charge the batteries before you use.
06 Abr 2017 14:57 #2
chinokemao2
Desconectado
Usuario baneado
Re: IMALENT FLASHLIGHT TIPS FOR NEW MODELS
Imalent escribió:When you receive your IMALENT new models DT70, DT35, DN35 or DN70, follow the steps if it doesn't turn on:
yo os pregunté por aquí y por correo un problema con una IMALENT, y nunca respondisteis, para mi sois de lo peor en servicio post venta
Volver a Imalent
¿Quién está conectado?
ForoLinternas ©
