Ranking de donantes
IMALENT DDT40W CREE XP-L neutral HI LED portable flashlight
21 Abr 2017 05:20 #1
Imalent
Profesional
Desconectado
MEET THE IMALENT DDT40W
The DDT40W is a portable high powerful flashlight, with a maximum brightness of 4500Lumens spot light and 1180lm flood light.
Imalent's 'Shark Series' model DDT40W, multi-functional touch screen controlled flashlight, utilizes 6 LEDs to offer a broad range of illumination options and power display function. Output up to 4500lumens+1180lumens lumens creates intense area lighting combined with long reach. Idea for group leaders needing high output and multiple beam patterns, the DDT40W is a powerful addition to a team's onsite lighting tools with instant high, strobe and SOS.
What can the DDT40W do? Whatever you ask it to!
High output with compact size; with a ridiculous output of up to 4500lumens, there's nothing this flashlight won't illuminate
Infinite brightness from 5lumens to 4500lumens or side lights 5 lumens to 1180lumens + three special modes; no matter the terrain, no matter the environment, your DDT40W will respond to just about anyway you'd like it to.
OLED display, shows lumens output, voltage, charging status, temperature and especially the digital compass; You won't missing your direction with this flashlight in dark wood.
Rechargeable, including 4pcs original IMALENT rechargeable 18650 batteries; Our Imalent batteries are like our flashlights, some of the best in the business. We like to know our customers are safe and so always include our Imalent batteries with our flashlights, the best deserves the best!
5. Side flood lights best for camping
Features:
Utilizes 4pcs CREE XPL HI Neutral White LEDs,and 2 pcs XP-L LED with a lifetime of up to 50,000 hours
Backlit touch screen panel facilitates convenient and discreet and infinite brightness adjustment.
Digitally regulated output - maintains constant brightness
Electronic reverse battery protection
Thermal control
Memory function
Battery capacity indicator
Working voltage:2.8-9V
Optimized deep metal reflector maintains great throw distance and spread with an ideal beam pattern
Dimensions:139mm(length) x68mm(head diameter)x50mm(tail diameter)
Weight:380g(battery excluded)
Aerospace-grade aluminum alloy body
Military Specification Type III- hard anodized
Ultra-clear tempered glass lens resists scratches and impacts
Accessories:O-rings, Holster, Screen protector , 4pcs MRB-186P26 batteries
What's in the box?
Our DDT40W comes with the following Standard Accessories:
Holster
Charger adaptor
O-Rings
User Manual
And 4 x 2600mAh 18650 Rechargeable Li-Ion Imalent Batteries
Please be noted: We have DDT40 (white LED) and DDT40W (neutral white LED), this sales post is for DDT40W not DDT40.
Volver a Imalent
¿Quién está conectado?
ForoLinternas ©
