Ranking de donantes
NEW launched! SKILHUNT DS21 XP-L 1000 lumens 18650 EDC flash
19 Ago 2015 05:46 #1
skilhunt
Profesional
Desconectado
NEW launched! SKILHUNT DS21 XP-L 1000 lumens 18650 EDC flashlight
Specifications (ANSI/NEMA FL1-2009 Standards):
LED: CREE XP-L
Output: Mode 1 Mode 2 Mode 3 Mode 4
900 Lumens 340 Lumens 130 Lumens 9 Lumens
Runtime 2.5 h 5.5 h 16 h 120 h
Beam Distance:173 Meters
Peak Beam Intensity:7500 cd
Water Resistance IPX-8
Impact Resistance:1.5 Meter
Battery: 1×18650 or 2x CR123A,2x RCR123
Rated Range: 3V ~ 9V
Dimension:
Length 110mm/4.33inch
Head diameter 24mm/0.94inch
Body diameter 22.8mm/0.9inch
Weight: 52g(without battery)
Accessories: Clip, lanyard, magnet replace O-ring, Operator’s manual, Warranty card, Spare O-ring
Optional Accessories: Headband,Battery,Battery Charger
Features
1. Super bright & lastest CREE XPL LED, High-performance, High-efficiency and energy conservation.
2. Durable aluminum vacuum plating reflector, Efficiency reflection, perfect beamshot, excellent structure
and temperature resistance.
3. Toughened ultra-clear glass lens with 99% luminousness anti-reflective coating.
4. Rugged indestructible aluminum body with anti-scratching type III hard anodization.
5. Multi-level dissipating heat design, excellent heat dissipation. Flashlight head integrated construction, high
thermal conductivity.
6. Side switch button to transferring mode user-friendly interface to adjust output.
7. Four output levels and strobe, suitable for different environment.
8. Wide input range provides more choices of batteries.
9. Automatic memory function, remember bast used setting and can be preset to specific output mode
for instant access.
10. Reverse polarity protection, to protect from improper battery installation.
11. Low-voltage prompts function, the light will flash when the battery is low, remind user replace the battery
on time.
12. Engineered anti-slip knurling for a tightly firm grip.
13. Dual recoil absorbing springs, battery impact resistance.
14. Tail stand as a candle-light.
15. Tail hand hole design for lanyard use, to prevent accidental dropping.
http://www.skilhunt.com/product-detail/ds21-flashlight/
Volver a Skilhunt
¿Quién está conectado?
ForoLinternas ©
