Ranking de donantes
NEW release! SKILHUNT H02C RGBW Powerful headlamp
09 Dic 2014 12:08 #1
skilhunt
Profesional
Desconectado
Hello everyone,
Good news!
NEW release! SKILHUNT H02C RGBW Powerful headlamp.
Specification:
LED: CREE XML-Color LED
Weight:56g(excluded battery)
Power:1*18650 battery
Rated range:3V ~ 4.2V
Dimension: Length:110mm/4.33 inch
Head diameter:25mm /0.98 inch
Body diameter:22.8mm
Lens:P.T.I.R Lens
Color:Black
Waterproof to IPX-8
Impact Resistant:1.5 Meters
Accessories:Opetator´s manual, Warranty card, Spare O-rings, Magnet replace O-ring, Lanyard, Clip, Headband
Optional accessories: Battery, Charger
Wight light modes: / Runtime:
Turbo 260 LED Lumens / 2 Hours and 30 Mins
High 140 LED Lumens / 5 Hours
Med 50 LED Lumens / 12 Hours
Low 2 LED Lumens / 480 Hours
SOS 260 LED Lumens / 5 Hours
Beacon 260 LED Lumens / 5 Hours
Color light Red Green Blue
DWL 620-630 nm 520-535 nm 450-465 nm
OUTPUT Hi 100/ Lo25 LED lumens Hi 150/ Lo 30 LED lumens Hi 30/ Lo 5 LED lumens
Runtime Hi 3.0/ Lo 18 Hours Hi 2.5/ Lo 18 Hours Hi 2.5/ Lo 18 Hours
Easy and Trusty user interface operation:
1. When the flashlight was OFF status:
- Click the side switch to White Mode brightness level, cycle as Lo - Mid- Hi - Turbo. Quickly double press side switch to Color High Mode.(Double press back to White light mode.)
- Hold press the side switch 0.5 second to Color High Mode, cycle as Red - Green - Blue. Quickly double press side switch to White Mode.(Double press back to Color High mode.)
- Quickly double press side switch to Color Low Mode. Double press to specical mode, cycle as SOS - Beacon. (Double press back to Color Low mode.)
When the flashlight was ON (any mode) status:
- Hold press the side switch 0.5 second, turn off the flashlight.
Low voltage indication:
When the battery voltage drop down, the light will blink three times every 2 minutes.
Features:
1. Super bright & lastest CREE XML-Color LED, High-Performance, High-Efficiency and energy conservation.
2. P.T.I.R Lens, Efficiency reflection, perfect beamshot.
3. Four output levels and Strobe, suitable for different environment.
4. Flat tail with strong magnet to secure to ferrous surfaces.
5. Rugged indestructible aluminum body with anti-scratching type III hard anodization.
6. Multi-level dissipating heat design, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity.
7. Side mode switch button to transferring mode, user friendly inerface to adjust output.
8. High efficiency driver circuit.
9. Reverse polarity protection, to protect from improper battery installation.
10. Low-voltage indication, the light will flash when the battery is low, remind user replace the battery on time.
11. Engineered anti-slip knurling for a tightly firm grip.
12. Dual recoil absoring springs, bettery impact resistance.
13. Tail stand as a candle-light.
14. Tail hang hole design for lanyard use, to prevent accidental dropping.
http://www.skilhunt.com/products.php?youxi=68&name1=&name2=
Volver a Skilhunt
¿Quién está conectado?
ForoLinternas ©
