New Announcement: L35 Immense Output&Effective Tactical Flashlight with Dual Switch
Subforo dedicado de Acebeam
11 Nov 2020 05:28 por Acebeam
Profesional
🔥🔥🔥 The Acebeam L35 is a super bright tactical flashlight that blasts a max output of 5000 lumens and a max beam distance of 480 meters (CREE XHP70). Also, L35 is offering a new LED option with LatticePower P70 for more long beam distance. Powered by a single high capacity 21700 battery, the L35 has impressive outputs and beam distance. It has a body diameter of 1" so it is compatible with most weapon mounts. The side switch is for a everyday activation and the tail switch can be used for tactical purposes or remote pressure switch attachment. The L35 was designed for tactical, hunting, duty, law-enforcement, search and outdoor use.
✅ Maximum output 5,000 lumens with a throw of up to 480 meters
✅ Can be mounted on different kind of guns with proper equipment.
✅ 6 brightness levels option plus special Strobe
✅ Powered by 1 x 21700 (Recommend ACEBEAM 21700 USB-C rechargeable battery)
✅ 1-meter impact resistance, IP68 waterproofing
Click and Get More Info: 👉 https://www.acebeam.com/l35
20 Nov 2020 08:28 por Acebeam
Profesional
Re: New Announcement: L35 Immense Output&Effective Tactical Flashlight with Dual Switch
Acebeam escribió:
11 Nov 2020 05:28
ACEBEAM L35 Is A Worthwhile Purchase in the end of 2020.
26 Nov 2020 11:09 por Acebeam
Profesional
Acebeam escribió:
20 Nov 2020 08:28
Acebeam escribió:
11 Nov 2020 05:28
26 Nov 2020 11:15 por Acebeam
Profesional
Acebeam escribió:
26 Nov 2020 11:09
Acebeam escribió:
20 Nov 2020 08:28
Acebeam escribió:
11 Nov 2020 05:28
