New Announcement: PT40 Extreme Performance Multipurpose Pocket Work Light
Subforo dedicado de Acebeam
27 Nov 2020 11:57 por Acebeam
Profesional
PT40 Multipurpose Pocket Work Light/Magnetic Headlamp/Wide Angle Beam Flashlight
Acebeam PT40 is the multipurpose pocket work light, can be used as a L-shaped headlamp, also a compact EDC torch and an angled work light which provides all the versatility you need to handle almost any task. Equipped with a line of 6 pieces powerful LEDs for high output brightness, up to a 110° angle beam with evenly diffused light as well as ultra bright area/work light. Powered by one single 18650 rechargeable Li-ion battery. Featured a single switch for easy and fast to operate.This pocket flashlight is ideal for your home and auto emergency kits, glove box, backpack or purse. You can clip or wear it to most anything for hands-free lighting. Magnetic tail stand it to put the light where you need it. The aerospace-grade aluminum body design is shock-proof and water-resistant which can provide more functions and in more environments.
Utilizes a line of 6 pieces LEDs
6 Lighting Modes Plus Strobe
Flood beam 110° angle
Removable pocket clip
Strong magnetic base
One switch for simple operation
Can be used as a headlamp&EDC Torch
Click and get more info: https://www.acebeam.com/pt40-extreme-pe ... work-light
With exquisite appearance, excellent performance and waterproof rating up to IPX-8 standard, Acebeam develops a multipurpose pocket work light PT40 which is successfully meeting a need for outdoor sports activities,industrial work and vehicle repair.
Come&Join our official group if you have not yet.
https://www.facebook.com/groups/acebeam
