Duda Ultrafire led t6 con zoom
17 May 2015 11:44 por jomertab
Re: Duda Ultrafire led t6 con zoom
XP-L
Introduced in May 2014, the XP-L puts the same size die as the XM-L2 onto the smaller 3.5mm board of the XP-G (shaving off the edges of the dome to make it fit). Due to the larger die, it will not throw quite as well as the smaller die of the XP-G, but it puts out more light and can be driven at higher currents. Binned at a higher current than the XM-L2, higher bins are typical for the XP-L, but a V5 bin XP-L is roughly equivalent in output to a U2 bin XM-L2. In April 2015, Cree introduced a "high intensity" version of the LED with a flat coating instead of a dome that could offer the throw of a de-domed LED without the trouble.
Brightness Bins for Cree XP-L at 25°
(max is V6 bin)
Bin 1050mA 1500mA 2000mA 3000mA
------ 100% 135% 169% 225%
T6 318-341 429-459 537-575 715-766
U2 341-364 459-490 575-614 766-818
U3 364-387 490-521 614-652 818-869
U4 387-409 521-551 652-690 869-920
U5 409-432 551-582 690-729 920-971
U6 432-455 582-613 729-767 971-1022
V2 455-478 613-644 767-805 1022-1073
V3 478-500 644-674 805-844 1073-1124
V4 500-523 674-705 844-882 1124-1176
V5 523-546 705-736 882-921 1176-1227
V6* 546-569 736-766 921-959 1227-1278
XM-L2
Same 5mm x 5mm size as the original XM-L but with up to 20% more output. Introduced in December 2012. Like the XP-G2, the XM-L2 is silver on top, has two bonding wires, and the die has dots instead of lines. The XM-L2 is significantly larger than the XP-G2 and has a round hole at the upper left as opposed to the XP-G2's square hole. The LEDs are binned at 85°C, so the values shown below have been increased by 13.7% to make comparisons with other LEDs binned at 25°C easier. The first production lights to feature the XM-L2 were the ThruNite Catapult V3 and TN31 in January 2013, followed by a number of Xeno lights which also had options for neutral tints in Feburary. Press release.
Cree XM-L2 datasheet
Cree XM-L2 is the same size as the original XM-L, but a new design
Brightness Bins for Cree XM-L2 at 25°C
(max is U3 bin)
Bin 700mA 1000mA 1500mA 3000mA
----- 100% 138% 194% 328%
S4 186-196 256-268 360-377 612-641
S5 196-207 268-284 377-400 641-679
S6 207-227 284-313 400-439 679-746
T2 227-250 313-343 439-483 746-820
T3 250-273 343-375 483-528 820-895
T4 273-296 375-406 528-571 895-970
T5 296-318 406-438 571-615 970-1044
T6 318-341 438-468 615-659 1044-1119
U2 341-364 468-500 659-703 1119-1193
U3* 364-386 500-533 703-750 1193-1268
Ahí lo llevas
17 May 2015 19:35 por pepinfaxera
Carezco de conocimientos suficientes para dirimir entre todo el intríngulis de este tema, pero creo tener el suficiente para afirmar que es bastante complicado, no se puede simplificar con tamaños y luz emitida.
Entre otras dices :
Introduced in May 2014, the XP-L puts the same size die as the XM-L2 onto the smaller 3.5mm . .... but a V5 bin XP-L is roughly equivalent in output to a U2 bin XM-L2.
Mira estos datos de la linterna Xin TD C8 versión 5, que se puede adquirir con distintos led.
http://intl-outdoor.com/xintd-c8-v5-xml ... p-308.html .
Led & TintCool
Warm White - - XM-L2 T5 5D3
Neutral White --XM-L2 U2 3C
Cool White - - - XM-L2 U3 1A
Warm White - - XP-L U5 7A3 (80CRI Min.)
Neutral White - XP-L V6 3C
Cool White - - - XP-L V6 2C
El bin mas potente de XM-L2 de momento, el U3 y da luz de tonalidad azulada, 1A, 1B y similares
El bin mas potente de XP-L de momento, el V6 y da luz de tonalidad casi neutra 2C o incluso neutra 3D
http://intl-outdoor.com/cree-xpl-v6-2c- ... p-834.html .
http://intl-outdoor.com/cree-xpl-v6-3d- ... p-822.html .
Yo abandono esta discusión, No conduce a nada, Solo pido que, no se busque simplicidad donde la complicación es la norma.
17 May 2015 23:42 por luiscaracena
Gracias ... Buena info
19 May 2015 05:07 por ivan smash
Buenas amigos! Al fin pude traerles unas fotos de la susodicha. Aqui esta: Imagen
Tengan en cuenta que la camara de mi movil es muy precaria :rolleyes:
pepitogrito escribió:Sí, si sólo tienes que levantar la estrella no es difícil, pero no sé con qué sistema viene presionada contra el pill, y ahí puede que, no tanto que la rompas, sino que marques la plaquita de presión... así que hya que ir con cuidado.
El LED es superfácil saber cuál es... hay aquí un hilo "reconoce tu led" o algo por el estilo, con el que podrás comprobarlo.
La pila, me temo que es una UltraFake por lo que describes, ¿no? Deberías decirnos qué marca es :contrato: . Pero me temo lo peor... :gaydude:
Ya nos dices.
He aqui la duda pepitogrito de como levantar la estrella para ponerle pasta termica :(
Stay tactical
19 May 2015 12:45 por pepitogrito
ivan smash escribió:Buenas amigos! Al fin pude traerles unas fotos de la susodicha. Aqui esta: Imagen
Ya nos dices.
Pues fácil:
Tienes que hacerte con algo como esto:
Meter las puntas en los agujeritos de la placa metálica, e ir desenroscando con paciencia y tranqulidad para que no se te escapen las puntas y lo rayes (no pasa nada si lo rayas porque luego esa pieza queda oculta). :contrato:
Quitas esa pieza, que es la que presiona, y ya está: la estrella quedará suelta... Otra cosa será lo que te encuentres debajo... :gaydude: (Puede que sea un pil hueco, y entonces de poco o nada te sirvirá haber hecho toda la operación...). :roto2:
Luego, hay que montarlo todo bien montado, teniendo cuidado de que las distancias sean las mismas, de lo contrario, cuando cierres a tope el zoom, el led quedará algo difuminado cuando lo proyectes en una pared...
No pongas los dedos en el led, lo engrasarás... :silbando:
Saludos y nos dices.
Ah, no nos dices qué pila usas, y eso es importante... :roto2qtemeto:
19 May 2015 23:58 por ivan smash
Mis disculpas, he aqui la foto de la bateria tiene un logo con una BK y dice "led flashlight expert" y luego dice LS 18650 3800 mAh 3.7v li ion. Pero no se ve para nada prometedora...
Ya nos dices.
Claro, es que eso intente hacer, desenroscarlo de alli pero no logro hacerlo, no se si esta demasiado apretado o que es lo que esta sucediendo :S
Stay tactical
20 May 2015 00:22 por pepitogrito
De la pila, mejor ni hablar... :roto2:
Mala suerte, debe estar MUY apretado, así que no sé cómo demonio lo podrías denroscar... Lo único que se me ocurre es hacerlo con algo lo suficientemente largo como para aumentar el par de fuerza y así multiplicar tu fuerza para conseguir desenroscarlo...
De todas formas, recuerda: te puedes encontrar con una mala sorpresa... :contrato: Si un caso, para saber ANTES con qué te vas a encontrar, a lo mejor puedes extraer el driver, así sabrás qué hay debajo de la estrella... No vaya a ser que te partas las manos de hacer fuerza para nada... :nusenuse:
